Enable the collection of IPv6 multicast route statistics.
These statistics are not related to the interface (port) statistics. Rather, the statistics are displayed based on multicast group classification. By default, collection of multicast route statistics is disabled.
    enable
    configure terminal
  2. Enable the collection of IPv6 multicast route statistics.
    ipv6 mroute stats enable
  3. Optional: Set the IPv6 multicast route statistics to default:
    default ipv6 mroute stats
  4. Optional: Disable the collection of IPv6 multicast route statistics.
    no ipv6 mroute stats
  5. View the IPv6 multicast route statistics.
    show ipv6 mroute stats [WORD<7-400> {Ipv6address[,Ipv6address][,...]}]
    The maximum number of multicast group IP addresses is 10.
Example:
Enable collection of IPv6 multicast route statistics:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#ipv6 mroute stats enable
View the IPv6 multicast route statistics:
Switch:1#show ipv6 mroute stats
                     Multicast Stats
                     Statistics : Enabled
View the statistics for the multicast group IP address FF05::1:
Switch#show ipv6 mroute stats FF05::1
                         Multicast Stats - GlobalRouter
GroupAddress                SourceCounter      IngressPackets       IngressBytes    AverageSize
ff05:0:0:0:0:0:0:1          1                  1962750              2355300000     1200
View the statistics for multiple group IP addresses (up to a maximum of 10).
Switch#show ipv6 mroute stats FF05::1,FF05::2,FF05::3,FF05::4,FF05::5,FF05::6,FF05::7,FF05::8,FF05::9,FF05::a
ff05:0:0:0:0:0:0:1         1                  2027508              2433009600    1200
ff05:0:0:0:0:0:0:2         1                  2027507              2433008400    1200
ff05:0:0:0:0:0:0:3         1                  2027507              2433008400    1200
ff05:0:0:0:0:0:0:4         1                  2027507              2433008400    1200
ff05:0:0:0:0:0:0:5         1                  2027507              2433008400    1200
ff05:0:0:0:0:0:0:6         1                  2027505              2433006000    1200
ff05:0:0:0:0:0:0:7         1                  2027505              2433006000    1200
ff05:0:0:0:0:0:0:8         1                  2027505              2433006000    1200
ff05:0:0:0:0:0:0:9         1                  2027505              2433006000    1200
ff05:0:0:0:0:0:0:a         1                  2027505              2433006000    1200
Variable definitions
Use the data in the following table to use the show ipv6 mroute stats command
Variable
Definition
Specifies the multicast group IP address for which to display statistics.
The group IP address is in one of the following formats: a single IP address or a series of IP addresses.
You can specify a maximum of 10 groups.
